Creda 48149V 41100084 built in oven
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Creda 48149V 41100084 built in oven
  • #17011
    aqualectric
    Creda 48149V 41100084 built in, under-counter double oven.
    Grill regulator required. (or info as to where I’m going wrong)
    Original one was a Strix unit (burnt out). Found what I thought would replace it – Hotpoint grill regulator type 41ER101C1P. Fitted OK, no wiring probs, all numbered tags present = straight swap. Info on this regulator says it replaces Strix units. But……
    Grill works on full power only and regulator doesn’t ‘click off’ when turned back until it gets to almost the ‘off’ position. Would seem like the regulator is faulty. Is it suitable for this job? Connections show the replacement to be Diamond H type 31ER15HT (pt. no. 5031681934372). 😕
    Will this unit be tagged / numbered differently? If so, does it come with conversion sheet? Looks as if the switch and stat parts are separate in Connections photograph.
    Why do you always have these problems when it’s your son’s teacher’s machine??
    Serious need to look good on next visit!!! 8) 😆
    Thanks in advance,
    Steve.
    #172536
    goosegreen
    Re: Creda 48149V 41100084 built in oven
    Is it a single or duel grill
    Goose
    #172537
    aqualectric
    It’s a 4 bar ‘solarplus’ type unit. Don’t think it’s dual circuit as the numbers on the knob only go 1-6; no selection for half grill.
    #172538
    The actual p/no listed is 6226105 – looks like a long shaft energy reg with a selector switch mounted on the front.
    The “31” code means it’s single circuit, btw.
    Cheers,
    goosegreen
    I have got a 41ER101C1P in front of me did yours come with a wireing chart if not i will mail a copy.
    Goose
    #172540
    Dave_Conway
    On Partfinder, the original Strix is part number 6100762 which is the 41ER101C1P 😕
    #172541
    goosegreen
    6300304
    Goose
    #172542
    Dave_Conway
    Strange, they appear to be exactly the same simmerstat with different part numbers 😕
    Order the cheapest 😀
    goosegreen
    I think one comes with a link wire and one doesn’t
    Goose
    #172544
    wilf
    sounds like youve got the load on the pilot double check your wires these horrible little regs are a sod to see the numbers on. good luck
    wilf
    #172545
    aqualectric
    Mine came with no instructions; complained to Connect, they sent a replacement, still no instructions!! I took great care to wire it correctly,and checked each wire individually. But, I am not infallable, so if Wilf is right, how can I check this back? I also didn’t use the link wire as I couldn’t see where it would serve any purpose. Could this be my problem? If so, where does it go?
    Think I’m going to need that diagram please Goose; but my e’mail is down on my site (er.. page) so I’ve left you an alternative e’mail address in your private message box.
    Thanks for everyone’s help so far, but if you see a mushroom cloud filling the southern skies you will know why…… :zap:
    #172546
    maltheviking
    I have the wiring for Diamond H 40ER101C1 and 41ER101, I think the connections should be similar you may be able to work something out or for future reference.
    41ER101. Diamond H to Strix
    2 To 2
    P1to P1
    4 To 4
    4A(n) to S2
    If the 40ER101C1 is replacing either a Strix or Ego then the wire previously connected to terminal 4 should now be connected to Terminal 4A on the Diamond H
    The rest are 1 for 1
    Hope this is of some help they can be a pain to swap sometimes.
    If you have an account with Parts Centre, give them a ring they might have the relevent info.
