Creda 48171 Gainsborough Grill Problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda 48171 Gainsborough Grill Problem
  • #47743
    Rob666
    First post so please be kind.
    I’ve been attempting to fix a Creda 48171 with a non working grill.
    The element checks out OK both by meter and comparison/substitution with a new one.
    The secondary cooling fan runs when the simmerstat/energy controller is turned on but the element does not get hot.
    So, the question is, where next? The overheat cut-out relay, the energy regulator or what?
    Thanks for all suggestions.
    #294433
    Rob666
    Re: Creda 48171 Gainsborough Grill Problem
    Bump!
    Still looking for help on this one please.
    #294434
    Hi Rob,
    Most probably the energy regulator on that machine from memory if the element is okay.
    The only safety stat I can see as such is a fan control one.
    HTH
    Rob666
    Hi K,
    Many thanks for the reply. There definitely is an overheat cutout device on the grill as well. I’m guessing this should be closed circuit if it’s OK?
    I’ll haul the thing out again and check. If it is closed circuit then I’ll change the regulator.
    Rob
    #294436
    Yep, usually they will open to cut the power, normally live.
    twinspark
    its your simmer stat( two feeds )one to fan then to elements.
    some models have door switch ,on the door hinge
