creda 48301 cooker
  • #42088
    wilf
    this is twenty years old and over the years I’ve done loads but this one’s being a pain. fan motor seized so fitted a new one this one has a seal (6222716) not three fans the seal was rather hard and cracked but couldn’t get one so just fitted the motor it ran ok. got called back two weeks later the whole oven cuts out after about 5 mins then back in 2 mins later . I suspect the TOC on the motor (three wire motor) cutting out but this was not reported on the old motor with the same seal.
    have I got a dodgy motor? would a worn seal cause this? or am
    I missing something?
    wilf
    #272367
    goosegreen
    Re: creda 48301 cooker
    Is the model a Concept? if so it should have a rear cooling fan fitted maybe why the motors cutting out. 6221528 in stock at Masterpart.
    Goose
    #272368
    wilf
    fans fine thanks
    wilf
