Anyone got a circuit diagram for this cooker?. Problem is one half of the grill not working and on top oven neither half works. Are the two halves of the solargrill wired in series in top oven mode?.
Yes in top oven mode the grill elements are wired in series hence if one half is open circuit you will only get heat from the base element sounds like a duff high speed grill element i’m afraid, there are 2 elements for these need the date code to confirm one is priced £89 and the other £33.74
