Creda 48349 – grill no longer functioning – stat or grill?
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda 48349 – grill no longer functioning – stat or grill?
  • #58864
    jrec149
    Its the Concept Solarplus model and it is getting on in years but likely to be cheaper to fix in short term.
    Any ideas whether it is likely to be the grill element or the energy regulator/simmerstat or whatever control? And how do you work it out?
    Is this the stat: http://shop.ukwhitegoods.co.uk/Cooker+{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} … lator.html
    The grill element is ‘easier’ to work out!
    James
    #335944
    Re: Creda 48349 – grill no longer functioning – stat or gril
    Does it have a solar grill element or the standard bar elements?
    Either way you can access the terminals from the back to test the elements once you have isolated the cooker from the mains of course.
    Usually one side of the element will go before the other.
    Correct regulator is a 6204036 or its Indesit number which is C00229540.
    If it is the element that is at fault and you do have the solar grill in it then take care if you order one. Check the parcel as soon as it arrives, even from trade suppliers I usually get every other one of these with the glass tubes broken on delivery. 😥
    The part you have linked to is an oven thermostat, not a regulator. 😉
    Also that price is about £10 to £15 over the top. :rolls:
    #335945
    jrec149
    Quick response thanks.
    Standard bar elements.
    Failed all at once.
    Therefore regulator seems more likely?
    #335946
    It would point to that but its still best to test the elements first. If it has the bar type elements then it is just possible to remove them from inside the cavity to test them without pulling the back off. In most cases though they will tend to look distorted or split if they have failed.
    Changing the regulators is quite a difficult job on these machines so making sure you do need it is advisable. 😉
    #335947
    ghostlymoron
    I have a similar problem. How should I test the elements? Presumably with a multimeter but what resistance should it show? Thanks GM
    #335948
    The actual resistance isn’t that important TBH, it’s more to check if the element has been become open circuit.
