Re: Creda built-in diswasher door problem
This is possibly a Fagor produced machine, It will need removing from its position to take off the side panels, door front panel also needs to be removed. The springs may not be faulty, it is more than likely that the ‘rod link’, the flat metal strip that attaches to the door, on one or both sides has failed. This is something best left to someone who has experience on these machines.
PS. The ‘so called manual’ is perfectly adequate for its purpose, it is a ‘user’ manual, not a ‘service’ manual after all.
