Creda C361E Timer
  • #11783
    coltnavy
    Hello
    I have had an occasional problem with the timer on this oven. Over the last few weeks the timer button has had to be continually pressed to move from the time to timer set. Now, the timer is flashing auto and will not react to any of the buttons being pressed. So can’t use the oven.
    Any suggestions on a fix?
    many thanks
    #146637
    Del
    Re: Creda C361E Timer
    Timers are not really a serviceable item. The only realistic option is to replace the timer unit.
    Del
    #146638
    Several different control units for this cooker, to identify we would need full model number such as C361ED and the first two numbers of the serial number.
    Definately not a DIY repair.
