creda c361ew cooker
  • #56189
    mowerman80
    As above which is the right main oven thermostat for this cooker ,it has a small black looking stat on there but cant find one the same ,has it been replaced with a different type.thanks.
    #326489
    Re: creda c361ew cooker
    Main oven stat has been changed a couple of times, need exact serial number and date code to even hazard a guess as to correct part. 😥
    #326490
    mowerman80
    Ok date code etc 90100402 hope this helps.
    #326491
    Its more than likely that you need a 6203969. Is it a single stat or a selector switch and stat combined.
    If it is just a single stat then that one is the correct part number. It is for machines after date code 26, yours would appear to be DC 90. That seems like a long time after DC26 though. :con:
    I will try and sort out some more info for you.
    mowerman80
    Thanks for all the info ,it has a seperate selector switch with the 2 pole stat clipped on the back. all the info i have seems to contradict its self. so if i use part number 6203969 do i need to remove the selector switch or does it go on the back as it is now? Also could it be part number 6222155 .It said in the tec bullitin to use part number et50000/j5 but you said part number 6203969 which is different. Why cant companys just use one stat for all ovens? would make life alot easier.
    #326493
    Thats why I said you need to hazard a guess, 😥
    The serial number you gave doesn’t seem to match the age of these machines TBH.
    I think the 6203969 is only for the combined unit. :con:
