creda c362ew
  • #33878
    briathlon
    Hi folks, can anyone please help with a fault i have on the above cooker, the symptoms are as follows:
    1. Switch on at cooker switch. Oven fan and cooling fan come on. Timer flashes.
    2. Open oven door: Oven fan stops, cooling fan continues. Oven heating neon illuminates. Oven does heat.
    3. Close oven door: Oven fan starts. cooling fan continues. Oven heating neon goes off.
    Im not going to see the cooker until during the week and as its a fair distance away it would be nice if i could go armed with any parts im going to need.
    I did search the forum and found a thread started by whitevanman1 with the same fault on a c361ew but theres no reply to it.
    if no one knows what the fault is would anyone have a wiring diagram for it. thanks in advance.
    regards
    Brian
    #240448
    johnnyj
    Re: creda c362ew
    New stat required, jj
    #240449
    briathlon
    Re: creda c362ew
    thanks very much for the quick reply jj.
    i’ll get a new stat ordered then.
    regards
    Brian
