Hello all ,
My creda C362e main oven has stopped working , I fitted a new element as the heat was not working, it has worked very well for a couple of weeks until the cooker has now stopped working again. but……this time the internal light, fan and heating element is not working.
The top oven works fine and the hob works fine it does not have an auto timer just a minute minder.
I have tried to find the model number but there does not seem to be a plate anywhere on the cooker there is a sticker behind the seal on the main oven but it completely obscured and unreadable.
I know you need numbers but a nudge in the direction would be appreciated I suspect that it may be a trip switch or thermal cut out?
thermostat or could even be a wiring problem, You’ll need a multimeter to be able to check wiring for continuity to determine if there’s a wiring fault tho
