Creda Concept 361E
  • #29520
    Abbeypost
    Having changed the thermostat, if l turn the oven on it starts to heat, but when l open the door it trips the breaker. Any ideas please?
    #223494
    clivejameson
    Re: Creda Concept 361E
    Wiring fault changing the stat, earth fault somewhere, faulty door switch/wiring?
    First thing is to check for a short circuit with the door open, then check for earth faults.
    Power off at all times of course :zap:
    #223495
    clivejameson wrote:Wiring fault changing the stat,
    looks like you are spot on Clive,
    http://tinyurl.com/2vabd3 😥 It may be time to ‘get someone in’ 😉
