Creda Concept 361E main oven problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Concept 361E main oven problem
  • #14305
    kh
    Hi I have a problem with my Creda Concept 361E oven.
    We were cooking a chicken and noticed the cooker had stopped working. I checked the house fuse box and noticed that it had tripped.
    When I put it back on the rings/top oven/Grill all worked ok. but the main fan oven didnt, the oven indicator light on the switch (which stays on till a temperature is reached) comes on, but the oven doesnt heat up.
    Does the main oven have its own fuse or is this something more serious.
    I am currently trying to switch power off for 30 mins to see if it resets, but that is probably a long shot.
    Anyone any ideas ?
    #158937
    Re: Creda Concept 361E main oven problem
    Your fan element has blown, no amount of re setting will fix it I am affraid. Not an expensive job though.
    #158938
    kh
    I forgot to add that the fan still works as well.
    Is the fan element a job that I could do ? and approx how much is the element ?
    #158939
    Dave_Conway
    The element can be found HERE 😀
    #158940
    kh
    Thanks for that I’ll order it today, could you give me a link for the bulb that this cooker needs as well.
    #158941
    If you remove the bulb and take it to any local independant electrical retailer they should stock these fairly standard 15W bulbs. Much cheaper than from the manufacturer.
