Creda Concept Ceramic (48350) Twin Grill Problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Concept Ceramic (48350) Twin Grill Problem
  • #15803
    muffy40
    I have the above cooker and the grill has developed a fault. It has a twin grill element which can be used either as a double or single. It began to function intermittently when sometimes neither would work and other times only the single would work and occasionally both would.
    Now neither will work whatever the setting. Does this suggest a control switch as I would think it unlikely that both elements have failed together?
    Thanks for your help.
    #166393
    Re: Creda Concept Ceramic (48350) Twin Grill Problem
    Energy regulator for grill may have failed (p/no 6203590) or the selctor switch, which is part of the top oven thermostat (p/no 6201876). Burnt out wiring also a possibility.
    Power off if investigating; click the link below for an engineer if you re not confident.
