I have one of the above model no 48339.
The control switch for the front RH ring has become loose causing the Knob to fall off.
Does any one know how to access the switch to tighten it up. I have loosened various screws etc on the cooker but am unable to lift off the ceramic hob to gain access.
Also where can I get hold of a repair manual for this cooker.
Almost all hobs require removal of an access cover or even the entire lower cover to reach controls. Power off of course; if you’re not sure what you’re doing check Directories or Repairs@ for a UKW repairer in your area.
Re: Creda Concept Solarplus Cooker Control Knob Access
Accessing the controls on this appliance is not easy, more than the hob needs removing to access all the screws involved. I would strongly recommend doing as P45 suggests and look in Repairs@
To be honest, it is very rare for this type of control to work loose, its sounds as though the control itself may have failed.
I’ve got a Concept C363E and when it was delivered several of the knobs were loose – they could be lifted off the stem underneath and would spin without having any effect on the hob or oven it was meant to control. Creda simply sent out some new knobs and on insepction it was the spring clips inside the knob that were missing. Could this be your problem?
