Creda Concept Solarplus grill alternates on/off continuously
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Concept Solarplus grill alternates on/off continuously
  • #64241
    4qh4zw
    Our Creda Concept Solarplus grill alternates on/off continuously (accompanied by a clicking sound). The model number is 48349. I found a previous thread http://www.ukwhitegoods.co.uk/forumsphpbb3/viewtopic.php?f=36&t=3030 from 2005 which covers the exact same problem for the identical model number.
    The link from that thread is broken – hence this new query. It does allow me to ask:
    a) Is the resolution (a Strix dual simmerswitch) still valid, or is there a newer solution?
    b) Can I purchase the necessary part (whatever the solution) through this site?
    Many thanks
    John
    #356499
    Re: Creda Concept Solarplus grill alternates on/off continuo
    Hi John,
    Assuming it’s a dual regulator used on the grill then it’s this one:
    http://shop.ukwhitegoods.co.uk/Cooker+{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} … lator.html
    There’s only two types used on that cooker a single circuit and a dual circuit and you will often find the same regulators used for hotplates and grills.
    HTH
    4qh4zw
    Spare part arrived very promptly, and easily fitted – once I’d managed to deduce how to remove the ceramic top.
    Many thanks for your help.
    regards
    John
    #356501
    RussellR
    John, Any chance you could advise me how to remove the ceramic top ?. I have a similar problem and can’t figure out how to get into the back of the control panel without wrecking the top !
