Creda Concept Solarplus Grill problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Concept Solarplus Grill problem
  • #7282
    Anybody know why our grill should suddenly start going on and off when in use?
    It cycles about every 30 seconds from full on to off on both part and full settings.
    I’m suspecting the controller/thermostat is at fault but don’t know where to start looking or testing.
    Steve
    #122455
    Re: Creda Concept Solarplus Grill problem
    Morning,
    The grill regulator is not a repairable part on this. You will have to replace it, are both halfs of your element working ok?
    Do you have a model number for this appliance..5 digits long ie 48309???
    Kevin
    #122456
    Thanks for the reply
    The Model number is 48349
    Both halfs of the element work as they should but cycle from full on to off repeatedly.
    #122457
    Dave_Conway
    That’s got one of those nasty Strix dual simmerstats which will almost certainly be the cause.
    The replacement switch is a modification to a different type.
    The part is around £20 offhand, I would recommend the conversion is done by an engineer though, unless you’re confident with electrical repairs.
    Whatever you do, disconnect the cooker beforehand 🙂
    #122458
    I’m quite handy with a screwdriver!
    Any idea where I would get the parts with instructions?
    #122459
    Dave_Conway
    You can get one right here, I’ve just added it to our shop for your convenience 😀
    Direct link:
    http://shop.ukwhitegoods.co.uk/c0022954 … -regulator
    It comes with limited instructions I believe, as in the wiring modification but that’s about it.
    Hope this helps.
    #122460
    Thanks for your help.
    I have ordered the part recomended
    Regards
    Steve
    #122461
    Part arrived today.
    I fitted it and grill is now working.
    Thanks for a great service.
    I will be recommending this site to all my friends.
    Regards
    steve
    #122462
    Dave_Conway
    Thanks for letting us know all went well Steve, and thanks for the recommendations 😀
