Creda condenser dryer
  • #91749
    Barnald2015
    Hi I have a creda condenser dryer the drum isn’t Turning and checked belt which is all ok and motor seems to want to turn but it’s as if there’s to much weight in it to turn the drum but actually there’s nothing in it so just wondering anyone got any diagnosis for it.
    #449120
    Re: Creda condenser dryer
    motor capacitor most likely. if you turn on with the top off and give the drum a push is should turn
    like
    https://shop.ukwhitegoods.co.uk/washing … -capacitor
    you will have to find it and get the value this one is 7uF which is most likely
    also moved your post to the correct forum
    #449121
    don
    Have you had your dryer modified as per the safety recall notice info here ? If you haven’t had the mod done the advice Hotpoint have given is the machine should not be used until the mod has been carried out.
    Don
