creda condenser dryer T601CW
Home Forums Public Support Forums Help And Support Washing Machine Help Forum creda condenser dryer T601CW
  • #9619
    can anybody help with the above dryer that is only blowing heated air on the high temp setting and cold air on the low setting
    #134883
    Re: creda condenser dryer T601CW
    I would suspect a partial element failure – it is a double circuit element, so one circuit has probably expired.
    thanks for your advice Penguin, can I get an elemement and if so where do you suggest? I have taken the back cover off and the element is partially broken.
    #134885
    timofleeds wrote:can I get an elemement and if so where do you suggest?
    From here : Shop@
    #134886
    I have looked in the shop but could not find the part can anyone direct me to the right page?
    Regards
    #134887
    There are two different heaters for this model. You will need the serial number, or at least the first two numbers of the serial number which is a date code. This will help us identify the correct part.
    Serial number should be on a stick on label just inside the door, sometimes also on back of dryer.
    #134888
    Dave_Conway
    If the first two numbers from the serial number are 82 or lower then it’s this one:
    http://shop.ukwhitegoods.co.uk/Tumble+D … ement.html
    83 or higher and it’s this one:
    Both just been added to the shop, that’s why you couldn’t find them 😀
    Hope that helps.
