Creda Condenser Dryer TCR2 How do I Remove the Top
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Creda Condenser Dryer TCR2 How do I Remove the Top
  • #26044
    percnica
    HI, Want to clean inside the blower and motor housing on my Creda TCR2 . How do I remove the Top cover and side panel to access these parts?
    Does it slide off after removing rear screws or do I need to unfastern the top cover by the front control panel same way ?
    Thanks Nick
    #208536
    hotpnt
    Re: Creda Condenser Dryer TCR2 How do I Remove the Top
    HI, just 2 screws at the back of the lid, then pull back sharply, the side panel has 3 screws down the back & one half-way along underneath
    #208537
    helo_75
    why you wanna clean it?
    neway
    undo the two screws, and, from the front, use the palm of yor hand, and forcefully push the lid backwards, dont be frightend of hitting it.
    the side panel comes off, 1 screw top front corner, screws at rear of machine, slide panel backwards and lift off
    ur in!!!!
    #208538
    percnica
    Thanks for that got the top and side off.
    Need to clean as bought second hand, the Thermostats had tripped so now works. But the whole thing is full off fluff, the condenser fins filter etc.
    The air in Funnel is full of fluff plus the input fan.
    Thats what I need to clean
    Now need to remove the cowling to access the impeller and clean
    Any advise on who this is removed?
    Thanks Nick
    #208539
    helo_75
    it wont be full of fluff in there m8
    trust me
    the cover only levers off with a screwdriver, so its quite tight
