Having problems finding the part number of the heater thermostat pair.Does any body know it? The stat has a light blue/cream spot on it.
Waiting on the edge of my chair with suspence,
Mike.
Further hot developments! Connect out of stock.
Looked at the light blue stat and found a pin hole on it. Stick a pin in it and it resets!!! I presume this is the one shot device which is now a two shot device. Has any one else tried this?
Many times, even drilled a tiny hole in the back of green spot 1701583 one to reset, you still need to investigate any possible causes of failure though.
