creda continental twin fan oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum creda continental twin fan oven
  • #16494
    gavin_blair
    creda continental twin fan oven – model 48167
    first off the bottom oven stopped heating I thought it must be the element..I havn’t got round to replacing it yet
    but now the top oven has stopped as well about 2 weeks after the bottom oven.
    The grill works ok,. but is it really the elements or are there fuses inside these ovens or what else could be causing this to happen. I want tobe sure before I spend the money.
    #170110
    Re: creda continental twin fan oven
    No fuses inside the cooker that could cause this, In most cases you can see physical damage on the element but not always. You cannot see/test the upper oven elements without dismantling the cooker. Also the controls and even door switches themselves can cause ‘no heat’ problems. If you have not got suitable test equipment and electrical competence, I would strongly advise you to seek help from someone who has. Try the link in my sig. Power off if you intend to proceed yourself.
    #170111
    gavin_blair
    Right the controls caused the ‘no heat’ problem for upper oven, when powered on “24 hrs” in display was flashing, so changed that and its working OK now.
    Still no heat in lower oven. No damage visible on the element. Is it possible for me to check if its OK? How?
    #170112
    I refer you to my first post, if there are no visible signs of damage, the proper electrical test equipment, and experience is required to determine the condition of the element. with the cooker isolated from the mains at all times.
    #170113
    Dave_Conway
    If, after testing you do find it at fault, it’s this one:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=338
