Its a 10 year old model 48413
About 8 months ago the oven stopped working, after a couple of weeks I was surprised to find it working again !
Was OK until a few weeks ago, then it failed again, with the same symptoms, and doesnt look like its going to work again.
The ceramic rings are fine
The top oven works.
The clock works, the oven programmer seems OK (at least, it still starts/stops the top oven correctly). The programmer is couple of knobs which set the start and stop times on the mechanical clock. Not one of the modern digital things.
But the oven doesnt heat, the fan doesnt turn, the oven pilot light on the control panel doesnt light up.
I found that the bulb in the oven cavity does need replacing.
I guess it could be the microswitch on the door, as that switches off the oven normally.
If the element has failed, wouldnt the pilot light be on ?
Any advice ?
