Creda Cooker 48341
  • #45921
    rocker
    It isn’t possible to turn down one of the hobs with energy regulator, I have fitted a replacement regulator diamond h, still have the same fault, I realise it could be a faulty regulator, I changed cables over ie. number 1 to number 1 ect. assuming they are the same no wiring dia came with regulator.
    I have wired the element into another regulator on cooker, worked ok.
    need to confirm cables are going to correct terminals.
    Cheers John.
    #287639
    goosegreen
    Re: Creda Cooker 48341
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=13199
    Have a look at Kwatts Pdf
    Lists wiring for all makes of Eng Regs
    Very handy!
    Goose
    #287640
    rocker
    Thanks goose.
    #287641
    DentedPorsche
    Hiya,
    If the new regulator had a connection 4A then that is the neutral now. On the older ones it was 4.
    If you can post the terminals from the old one and the new one I’ll work it out for you, unless you managed with the pdf.
    Brian
    #287642
    DentedPorsche
    Hiya,
    Got your email John, sent the reply.
    Brian
