Creda Cordialle oven door seal problem
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Cordialle oven door seal problem
  • #79039
    BlackKat
    Hi guys
    The door seal on my oven has come away on one side – I’m just wondering if it’s something I just need to push back on, or whether given the fact the oven’s 15 years old, I maybe need to replace it instead? 😕
    I’m disabled & have hand arthritis so even trying to push this back on is proving a bit troublesome but I don’t want to spend money unnecessarily.
    BK
    Belfast
    #407689
    Andy jones
    Re: Creda Cordialle oven door seal problem
    They normally clip in so it would probably need a new seal. A full model no would be needed though
    #407690
    A full model number would help, at least 26 different models under that name. Most oven door seals are fixed in at the corners with a small hook that slots into a hole in the body of the oven.
    The door seal is still available and is not over expensive, around £23/£24.
