Re: Creda CS61EW 17100049 Cooker not hot enough
When you say you checked all the elements, which ones did you check as there are several in that machine? And, which cooking mode are you using as I’m assuming from the elements fitted that it’s a multi-finction oven?
The easy one to miss and, it often is, would be this base element which is mounted at the bottom of the main oven.
There are also two side elements listed but there’s very little use on those at all.
There’s also an odd little board fitted, this one, but I can’t see where it’s fitted or quite what it does. 😕
HTH
