Re: CREDA Dishwasher Model 47917
wrpgh02 wrote:Is this hot fill or cold fill..
Cold fill only – hot fill will damage the water softener unit.
wrpgh02 wrote:Also you can see the heater element but the water never seems to cover it so how does this heat the water….
The circulating water falls down onto the element in sufficient quantity to do the job.
wrpgh02 wrote:How does it DRY…..because it doesnt seem first to heat up the water…
Last rinse is a hot rinse, releasing rinse aid into the water. The drying process is performed by the residual heat from that rinse.
wrpgh02 wrote:Could this be a heater element problem
Yes – also, safety thermostat may have failed or wiring problems in the door at the hinge point. Possible that the timer is not switching the heater on.
wrpgh02 wrote:Has anyone got a user manal for it or some pictures of the parts underneath the machine and what they do.
Manual is NLA from Creda – it’s a fairly old machine these days.
Under the machine you will find the wash pump, drain pump, water softener unit, inlet valve, water level pressure switch and thermostats. Don’t think I’ve ever seen a piccie of the underneath 😀 .
Power off if poking about…….
