CREDA Double Oven 48149V
  • #28179
    johnnyhoz
    Hi All
    Fitted two stats to the top oven but customer keeps complaining the the oven is 20 degrees hotter than it should be.
    have checked with a digital thermometer and it reaches 240 degrees when the oven dial only reads max 220
    any ideas please
    John
    #217261
    A1TEC
    Re: CREDA Double Oven 48149V
    Dose it reach the 240 degrees on the first heat up and dose it maintain that temp constant.?
    Most stats have a differential setting so most heat over on first run before settling down to chosen temp.
    This stops the stat cutting on/off constantly.
    #217262
    johnnyhoz
    It reaches 240 on the first heat up, drops to 220 then cuts in raises to 240 and maintains it
    #217263
    johnnyj
    As A1 says all stats overshoot required temp, to check temp you have to to take readings of a couple of cut outs and cut ins and work out average temp and you will find you are there or there about+or – 5 to 10′ C which is acceptable.
    #217264
    johnnyhoz
    Thanks guys I’ll check the readings
