hi guys have to fix a creda simplicty dryer mod no TS22vw need new door switch does the front come of this dryer to get at the switch or can you remove the outer door rubber thanks fasetester
thanks for the reply helo75 would there be much slack to change the switch that way up throught the top the thing is customer rung said child was at the dryer and broke the door catch is it just a push and pull on this dryer or a lach type like washing machine the said the replaced the door catch but still would not work the said the have a new door switch and would i come and fit it the migh have fitted the door latch wrong fase tester 🙂
hi guys it a while from i worked on one of these dryers how is the front face held on how do i remove it does the timer have to be removed thanks for any help i could have got the model number wrong it is t522vw 🙂 fasetester
