Creda reverse sensedry Model 37649
Serial 72100022
when loaded with clothes it will not start unless the drum is rotated by hand then closing the door and switching on when it works perfectly
If the drum is empty it works normally
Owing to this problem 8 months ago I purchased a BEKO dryer the engineer came last week for the third time since we have had it so the first breakdown after the garranty runs out it goes to the tip
This Technition told me the problem with the creda is the capacitor
My enquiry is what is the part number where could I purchase one and what is involved fitting it ❓
I was not sure whether you meant remove the right side panel and could not see how to so I removed the small panel from the bottom front and am confident I will be able to access it from there.
I have ordered the part
Many thanks for your advice
I always change them through that panel, stand it upside down and take care when pulling the wires off, not as easy if you have huge forearms though. 😉
