Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › creda dryer model 37747 no heat
- This topic has 10 replies, 3 voices, and was last updated 15 years, 1 month ago by
chaz.
February 18, 2011 at 3:03 pm #61154
chaz
Participantany one help no heat when operating i have changed thermostats and heating element still not heating all advice welcome
thanksFebruary 18, 2011 at 3:37 pm #345039iadom
ModeratorRe: creda dryer model 37747 no heat
You don’t mention if you actually tested the thermostats or the heater before you changed them, if not then it is not the best way to proceed.
If you do not have access to a megger or suitable multimeter and know how to use them, you should not be attempting to repair electrical appliances.
There is another thermostat in the door and a reversing timer in the base that could be at fault.
Changing parts on the off chance they may cure the fault without first testing them is a rather expensive practice.
February 18, 2011 at 4:16 pm #345040chaz
ParticipantRe: creda dryer model 37747 no heat
iadom wrote:You don’t mention if you actually tested the thermostats or the heater before you changed them, if not then it is not the best way to proceed.
green spot stat was open circuit and broken isulator in element caused element sections to touch so i changed stats and element also checked stat in door drum reverse,s while dryer operating been reading on google search about reset buttons and sticky floats also i checked relay at top of machine seems to operate ok sorry for not being more clear in my post going nuts trying to find problemFebruary 18, 2011 at 4:21 pm #345041iadom
No reset button on these, if the float switch is stuck or faulty that can stop the heater, not easy to get at though.
Even though the machine will reverse, the reversing timer switches both the motor and the heater on and off and does occasionally fail giving a no heat fault.
Have you rechecked the new green spot stat, if the base of this stat gets pressed in, even accidentally it will fail.
If the machine is running then the relay is OK.
February 18, 2011 at 4:25 pm #345042chaz
iadom wrote:No reset button on these, if the float switch is stuck or faulty that can stop the heater, not easy to get at though.
have checked stats all ok
any idea where i could find a circuit diagram for this dryer so i can check it out properlythanks
February 18, 2011 at 4:39 pm #345043iadom
Sorry, Rule eight applies 😥
February 18, 2011 at 4:42 pm #345044chaz
chaz wrote:
iadom wrote:
No reset button on these, if the float switch is stuck or faulty that can stop the heater, not easy to get at though.Even though the machine will reverse, the reversing timer switches both the motor and the heater on and off and does occasionally fail giving a no heat fault.
does the timer also control heater
February 18, 2011 at 4:44 pm #345045chaz
iadom wrote:Sorry, Rule eight applies 😥
my apologies for rule break
February 18, 2011 at 4:44 pm #345046Martin
chaz wrote:does the timer also control heater
Yes, together with the Reversing Timer. 🙂
February 19, 2011 at 3:21 pm #345047chaz
problem solved thanks to all for help
problem was heater contacts inside reversing switch they were carbonized due to arcing gave them a rub with one of wife,s emery boards to clean them will keep it working untill i get a new switch
once again thanks for help
February 19, 2011 at 7:16 pm #345048iadom
