Creda Dryer start / stops
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Creda Dryer start / stops
  • #39384
    midi
    CREDA Simplicity T622CW condenser dryer, approximately 6 years old
    The dryer starts and runs normally for a few minutes then stops. It will not restart until a few minutes have passed, then it runs normally, but stops again after a few minutes.
    Prior to the failure it was running normally with no indication of malfunction.
    The water tray is empty, good flow of air, filters are clean, dryer heats, but not excessive. Problem occurs on both heat settings and on any timer setting.
    The drum turns and there are no unusual noises or smells
    I had he thermosats replaced a couple of years ago – problem then was that the dryer was not heating.
    Regards
    #262290
    helo_75
    its the relay thats faulty!!!
    c ommon problem…. available in the online store
    #262291
    Re: Creda Dryer start / stops
    HERE
    midi
    helo_75
    Thanks for the advice – ordering one now
    Cheers
    #262293
    midi
    should have asked – before I start tearing the machine apart, where is it situated?
    Regards
    #262294
    helo_75
    under the lid, next to the timer…. bit fiddly, plug out when looking and make a note of where the wires go
    #262295
    midi
    Thank you
