Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Creda Ecowash – getting stuck! Help please.
- This topic has 4 replies, 2 voices, and was last updated 18 years, 8 months ago by
LittleMama.
August 9, 2007 at 8:03 pm #29645
LittleMama
ParticipantHello!
I’ve got a problem with my built in dishwasher and I’m hoping SKS will point me inthe right direction.
It’s a Creda Ecowash and it has started getting stuck at the rinse mode, about 10 days ago, and it always sticks there now but can be moved on. OH then had it sticking between rinse & drying but I haven’t had that problem but now it is sticking at the wash mode (last 2 runs have had this) too, just after it fills up. Again after being moved on manually it runs ok until it gets to rinse and needs nudged on again.
I wasn’t planning to get a new dishwasher at the mo and would like to eek out a bit more life in this one, as it washes ok….despite the manual move ons.
Any ideas on what I could do to fix it? 💡
Many thanks for reading.
LM 😉
August 9, 2007 at 11:32 pm #223977Penguin45
ParticipantRe: Creda Ecowash – getting stuck! Help please.
1/ Please find the model number – usually around the edge of the door somewhere. Ecowash doesn’t tell us anything.
2/ Does it heat the water?Regards,
Penguin45.August 10, 2007 at 9:06 am #223978LittleMama
Hi Penguin 45,
A model number would help wouldn’t it 😳
Have found the following numbers for you from the side of the door.
Model No 47908
No: 22146228I believe it to be heating the water as we’re still getting the steam coming out when we open it at the end of the cycle and it’s cleaning everything ok.
Best wishes
LM 😉August 10, 2007 at 5:55 pm #223979Penguin45
This is one of the old Bosch-based machines.
Timer stops to heat the water – thermostat must complete the circuit to restart the timer, so possibly one of the thermostats. These machines were also prone to wiring loom breakages in the door, near the pivot point – if one of the wires were from the thermostat to the timer, that would keep the timer stopped.
Power off if you plan to investigate; or click the link below for a UKW engineer in your area if you are unsure how to proceed.
Penguin45.August 10, 2007 at 9:09 pm #223980LittleMama
Thanks Penguin45.
I’ve passed this onto OH, I only fill and unload!!! 😛
Have followed your advice re a local chap and have his details for back-up.
Many thanks
LM 😉 -
