The other day our cooker blew its 30 amp fuse 🙁 . On replacing the fuse wire, we noticed that the oven bulb was not working but the fan was on constantly whether the oven was switched on or off 😯 . The oven heats up OK when you switch it on. The only way to turn the fan off is to use the cooker isolater switch.
When I came to replace the blown bulb, the new one did not work either 😕 . On checking the bulb holder it appears that the contacts for the bulb have ‘disappeared’ 😥 . I know I need a new bulb holder but I would appreciate it if anybody could advise me as to what is causing the fan to operate regardless of whether the oven is switched on or not.
Thankyou
