Creda Electric Hob Fault
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Electric Hob Fault
  • #6805
    Alsy
    I have an old Creda Cameo electric cooker.
    Just recently, using either of the two large rings causes the power to trip out.
    This does not happen when using the smaller rings, grill or oven.
    Any ideas anyone ❓
    Thanks,
    #119712
    Dave_Conway
    Re: Creda Electric Hob Fault
    Alsy wrote:Any ideas anyone ❓
    Yeah, the two larger rings both have an earth leakage fault and need to be replaced. I would imagine they are the spiral type, if so, not an expensive or difficult repair.
    Someone here should be able to help if you need them fitted, just let us know your postcode.
    #119713
    Alsy
    Thanks Dave, yes they are the spiral type.
    I’m sure I can manage the replacement, but I don’t understand why both rings can develop the same fault at the same time?!
    Do they share a control unit/power regulator?
    Thanks again,
    #119714
    Alsy wrote:Do they share a control unit/power regulator?
    The controls for each hotplate probably share the same live supply? Only a full check with an insulation tester will therefore locate the source. Time to get an expert in to check it for you 😉
