Creda Europa Solarplus oven door handles
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Europa Solarplus oven door handles
  • #27177
    NoCook
    I have a built in Creda Europa Solarplus Oven, in white, approx six to eight years old. The part number has long since fallen off. I require two new oven handles but without the part number of the oven I am totally stuck. The oven is 60cm wide and I would welcome any advice. I do not cook but Hubby is fed up with bits of plastic spoiling his creations! 😆
    Thanks,
    #212963
    eloc
    Re: Creda Europa Solarplus oven door handles
    I too have a Creda Europa Solarplus Double Oven in white which is nearly 9 years old. The model number of mine is: 48164 White. Hope this helps.
    #212964
    Door handles for a 48164 are 6201739, however that model is 55mm wide.
    Those handles do fit a 60mm model but there are at least two other Solarplus models of the same vintage with different handles.
    NoCook, can you post a picture of the front of the cooker, we may be able to narrow it down a little.
    NoCook
    Thank you eloc and iadom for your help.
    iadom in my ignorance of how these forums work I have emailed you a picture of my oven, hope that’s ok.
    Cheers and thanks again.
    #212966
    NoCook wrote:Thank you eloc and iadom for your help.
    Not received it yet, may have been binned by my anti spam software, 😥 Please send it again and I will look out for it or you can use a web hosting site such as photobucket, imageshack, putfile or similar then paste the url of your pic into a post on here.
    Just had a look at your pictures. I am 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} certain that the handles you need are part number C00194217. PLEASE READ NEXT POST.
    An e-mail to spares@ukwhitegoods.co.uk should get things sorted for you.
    PS. I am sorry I missed your first e-mail, I didn’t get to see the ‘wrong picture’ 😆
    EDIT. Please hang on before you order these parts. It looks like the spares ID software from the Indesit company has fouled up once again. It shows that handle as correct but entering that part number also comes up with a completely different handle.
    I will dig a little deeper for you.
    #212968
    I think your model number is an E420EW, unfortunately the official spares identification software shows the correct picture of the handle but the wrong part number.
    I cannot post your picture here because you embedded it in your e-mail. If you can send it to me again as a separate attachment I can post it up for others to have a look at.
    The annoying thing is if you enter the part number I have given you which I now suspect is incorrect into the Partfinder program, it shows that handle as fitting many different models but when you select a model it shows completely different handles. 😥
    At last, I think I have sorted it, model could well be an E420EE part number for handles is 6201739. A little more expensive than the other one at around £28.00 + vat.
    Before you go ahead and order, try and send me a picture that I can post so that someone else can verify my suggested part number.
    I am going to leave it there for now or I may end up dreaming about white door handles. 😉
    iadom wrote:dreaming about white door handles.
    “Just like the one’s I used to know…….”
    Good effort, Iadom 😀
    :p45:
    #212971
    This is the best I can do, unfortunately NoCook ( Joanne) had embedded this picture in the body of her e-mail to me so I was unable to copy or save it.
    I have printed out the e-mail then scanned it back in, here it is,
    Hopefully it will be clear enough for anyone familiar with this range.
    I think the handles are 6201739.
    NoCook
    Thanks Jim, I really appreciate all your time and efforts on this. I have placed an order for the suggested part number. Hopefully you can now get white oven door handles out of your head. 🙂
    Now, about that that little widgety gismo thing that fell off my tumble dryer……. 😆
    #212973
    Never mind that, I am still waiting to see the pictures you sent by mistake that I accidentally binned as spam. :snigger:
    NoCook
    Spot on Jim. Thank you, and all. I could send a photo of my refurbished oven but after last tiime…………
    Thanks for now,
    #212975
    Phew, I was fairly confident but with the Indesit Partfinder software you just never know.
    Thanks for letting us know. 8)
