Creda Fridge Explosion!
Home Forums General Trade Forum Creda Fridge Explosion!
  • #47954
    micromole
    Hi folks, if the fridge had R600a gas in it, that explains the problem. Had a leak and the thermostat set it off. Go off like a bomb don’t they? That’s why the regulation only allows a certain amount of R600a gas in them, to reduce this problem. Just imagine if the unit contained a couple of kilo’s of the stuff, the house would have gone, never mind the fridge!
    Couldn’t have been the compressor, as the source can be seen to be in the fridge compartment. Could be from leaking cream cannisters or aerosol cans containing Butane gas? I would have thought the customer would have complained the fridge wasn’t cool?(before the bang, if it was leaking gas) They’ve not been poking around with a knife to defrost or clean it have they???? There’s more than meets the eye with this one!
    Regards
    oldlonely
    Re: Creda Fridge Explosion!
    Being that the unit has not even been uplifted, it probably hasn’t had decent investigation…
    Be interesting to find what questions you would ask…..
    Has the unit still have a gas charge?
    Is that a yellow/brown discolouration on the right hand liner split?, very hot condensor..?
    It has a concealed fridge evaporator, seem’s no damage there?
    A leak maybe down by the compressor causing gas to enter fridge drain hole?…does this unit have a mechanical stat or board?
    What exactly was inside the fridge at the time? the freezer section looks fine, with the door intact.
    Did she get here hands on a jar of my mum’s Onions?
    Taking bets!
    O’l
    #295093
    It was a 2000 model from what I can gather so, the chances of this being an R600a explosion is, at best, slim.
    No repairs have been carried out so far as I know.
    Which leaves us only two options really, but looking at the photos, one…
    Something in it exploded for whatever reason.
    The other one which is less likely IMO is that something has been spilled onto/into the unit and ignited.
    Whatever the reason, given the givens, I can’t see it being a failure of the unit really. There’s nothing there that could go with that sort of force, I mean it destroyed the kitchen!
    spimps
    Interesting that the sweedish fire service investigating a similar event blamed it on a squirty cream container that was leaking,the propellent used is nitrous oxide which is produced from ammonia nitrates,it can also be used in rocket fuel 😯
    Is r600a used as a propellent in any cans?
    All manner of possibilities,lets hope they can find the true cause as opposed to giving possiblities.
    #295095
    roly16
    Am I missing something here? Where’s the beginning of this story?
    #295096
    nomadPaul
    roly16 wrote:Am I missing something here? Where’s the beginning of this story?
    here you go fella
    http://www.dailymail.co.uk/news/article-1207363/Mother-lucky-alive-fridge-mysteriously-exploded-turning-house-bomb-site.html
    #295097
    roly16
    Ah thank you! Don’t read the Daily Mail; much too left wing.
    There’s no sign of a fire so it couldn’t have been R600 exploding.
    It may say Creda on it but it’s a Brandt.
    #295098
    Ah – obviously a French Conspiracy in that case. Explosive orange juice would surely be a Detonation Cordiale….
    :p45:
    #295099
    micromole
    Hi folks, they use butane as a propellant in a lot of aerosol cans nowdays, changed from the cfc’s they used to use. Butane is the main constituent of R600a. So you go from one problem to another. I can see us having more explosions like this as the fridges get older, corrode and people poke about with knives, also the DIYer and cowboy get to mess about with them!
    David
    #295100
    micromole
    To Roloy16
    Don’t you check your e-mails from UK Whitegoods????
    It was sent to all of us the other day.
    Micromole
    #295101
    Emails? I never get emails from UK Whitegoods 😕
    #295102
    You need to subscribe to the newsletter in your account settings to get the news emails. 😉
    helo_75
    i wondered why this had never happened before
    its one of them blomberg things that leak behind the wetwall… they are r600 units
    usually they just stop working before blowing up, and they have a board not a pcb
    looking at the pic, the combustion started in the top right, just about where the gas leaks
    interestingly a lot of thermostats/pcbs are on the outside of the cavity, and now we know why
    #295104
    roly16
    Some of those Brandts have a thermostat and some a pcb, but I still don’t think it was an isobutane explosion.
    #295105
    expertcat
    Why do you think the likes of MFI,Iceland and Comet stopped using these.
    As they all suffered from internal gas leaks on rear wet wall.
    When I worked at EAC had to go round all iceland customers and put 8 holes from insulation so if and when leak happened the gas should shoot through these holes..
    It looks like a brandt.
    What made Ocean, Brandt go bust these dam units they never solved the problem.
    We even had one of these badged as icelands own make that went up causing a bit of damaged brandt came over and hastley removed fridge evaporater as these are internally lokringed not braised and they said the the insulation had corroded the lokring causing the leak.
