Re: creda fridge freezer isnt cold anymore
It’s definitley a system failure I’m afraid.
Either the compressor is failing or there is little or no gas in the unit which is why Clive asked about the defrost process. As it was working before, if any attempt was made with a sharp implement to remove any ice it’s very easy to puncture the internal pipework.
Engineer time to confirm, unless you inspect the inside of the freezer for any punture marks, if there are any, then it’s a new fridge/freezer 🙁
