Re: CREDA IW160D Power Button won’t work
I have had a ‘Pro’ to look at the machine and it turned out to be the on/off switch that had gone. They are very easy to get to removing the lid off the top of the machine to get to the row of switches. He spent 5 minutes and quoted £47 ‘Ouch’. He has temporarily put a switch on untill the correct swich arrives. Be sure you get the correct switch as mine is on when pressed in and the temp switch is on when de-pressed.
Still I wouldn’t have known without his help.
Please can you place an item link to the On/Off switch for the IW160D as this was the problem. After 2 years of use I think everybodies will start to go too.
Cooky
