CREDA IWD12 washer/dryer integrated
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries CREDA IWD12 washer/dryer integrated
  • #22247
    cornflakes
    good morning all
    have just visited above machine.
    problem found machine not draining..water still in drum..programme dail rotating
    clears water via sponge and filter
    found £2.30 in filter housing.. fine pump shot it i thinks!
    struggle to get washer into kithen, clever carpenter had floored up to legs
    replace pump ..test prior to putting back
    same symptom..checked voltage on pump..4.3 volts and drain and spin selection
    so dail spinning..mains on light flashing
    any ideas welcome while client continue flooring under machine.
    regards
    Graham
    Leicestershire
    #194198
    Re: CREDA IWD12 washer/dryer integrated
    Count the number of flashes between pauses from the mains neon, then check it against the Indesit fault codes in the Known Error codes thread.
    Page #2, post by lotusray ( I have added Creda to the post ) 🙂
    I would get the client to put some castors on it, it will be coming out on a regular basis until it is replaced with a decent quality machine.
