Creda main oven doesn’t reach temperature
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda main oven doesn’t reach temperature
  • #82477
    flashheart8
    Hello all, new to this site and would love some advise.
    I have a Creda double oven 48167 T, last couple of weeks the main oven has been taking an age reaching temperature, fans working, door seal ok, thermostat light comes on and goes off but the oven has not reached the correct temp, no where near?
    Tried to use it last night and got warm (not hot)and failed to cook anything.
    Any advise would be great.
    #420019
    Re: Creda main oven doesn’t reach temperature
    if the thermostat light goes out then it will stop heating until it comes back on again. if that is the case then
    it either
    1 the temperature sensor in the oven has come loose and is now either touching or too close to the element. your looking for a long thin silver rod with a thin wire coming out of one end. beware this is not electrical and the wire is full of oil. if it breaks while your handling it then its scrap. it is fairly tough but keep bending to a minimum
    2 the thermosat has failed. this will mean you have to replace the control behind the knob but it also includes the sensor above so you have to strip the panels of the unit to thread it through
    Hope it helps
    flashheart8
    Thanks Dave,
    I was thinking it could only be the stat, i’ll have a look and post my findings.
    #420021
    flashheart8
    Hi Dave,
    The stat is in place with nothing loose,all spade connectors behind the switch look fine.
    I take it there is no way of checking the stat and the only way to be sure is to replace it?
    #420022
    SAMURI
    It may be the fan oven element faulty.
    Set the oven on fan heating only and check to see if the stat cuts out and if any heat is produced.
    If the light stays on and the stat does not cut out it will be the fan element.
    Bob
    #420023
    flashheart8
    Thanks Samuri,
    I’ll try that now.
    #420024
    flashheart8
    SAMURI wrote:It may be the fan oven element faulty.
    Bob
    Hi Bob,
    Set to Fan heating only,no stat light comes on fan in the back doesn’t spin and no heat?
    Also tested element and it’s 23 ohms.
    Ian
    #420025
    flashheart8
    Quick update for any similar problems.
    The main oven fan was working but on closer examination, it stalled periodically and has now stopped completely (works with a helping hand from a screwdriver but not advised).
    A little harder to change as it means taking the back off the oven to, new part only £14.
    Thanks for the help guys.
