Creda Menu 350 cooker
  • #16768
    reaper
    Actual model number missing (sticky label behind plinth??) Need to know part number for single simmerstat please.
    #171437
    Dave_Conway
    Re: Creda Menu 350 cooker
    There’s over 20 “Menu” models listed, none with 350 after the name though 🙁
    Any number on the stat or the model may be inside the user manual if they still have it ?
    #171438
    reaper
    Thats the problem no model no. in the book either. These are awkward little devils to get at the simmerstats, half an hour to get at the simmerstat to see if it has a number on it, half an hour to put it back together so they can cook.Order part, half an hour etc.-time is mounting up. 3 hours plus 3 calls,how can you charge approx £100 for a simple switch on a cheap tinny cooker? Number 350 is correct both in the book and on the cooker.Simmerstat has the wider shaft.
    #171439
    Dave_Conway
    Sussed ! 😀
    The model is actually M350.
    Part number for the simmerstat is (or should be) 6204034
