creda model 37747 service manual
Home Forums Public Support Forums Help And Support Washing Machine Help Forum creda model 37747 service manual
  • #61167
    chaz
    anyone have a spare copy of service manual no heat fault driving me nuts
    wife moaning she wants new dryer but i aint giving up with this fault
    all help appreciated
    thanks
    #345104
    Specialist01269
    Re: creda model 37747 service manual
    Sorry mate: As Iadom pointed out to you earlier, No service manuals provided. Please see rule 8.
    #345105
    chaz
    sorry thanks for pointing that out
    could you possible tell me wher float chamber is located
    thanks
    #345106
    The float chamber is directly underneath the condensor chamber.
    If you look at the back of the machine the small black rubber bung is attached to the float chamber outlet.
    You can see the float switch if you remove the right hand ( from front ) side panel, its just behind the motor.
    Access is very limited.
    I have changed the odd float switch without removing anything else but it was very difficult indeed. 😥
    It is possible to reach the float switch to test it though.
    PS. It is not a good idea to start another thread on exactly the same topic, it only leads to confusion.
    #345107
    chaz
    thanks for advice iadom
