Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › creda oven
- This topic has 3 replies, 3 voices, and was last updated 21 years, 4 months ago by
admin.
December 10, 2004 at 11:40 am #7078
KeymasterI got CREDA MENU 350.
THE oven light stoped working. In the instruction manual this is easy:
replace the cup clockwise, then unscrew the light bulb and replace it with a new one.Damn it folks, that CUP can`t be taken out clockwise or otherwise, dont know what to to do.
Any advice welcomed.#
thnx in advance from
JACK.December 10, 2004 at 1:37 pm #121299Martin
ParticipantRe: creda oven
Jack,
Not clear on the oven you describe as we work on manufacturers model numbers 😕 However, it is a general rule that ‘Oven Lamp Lenses’ unscrew ANTI-clockwise in the main.
First do please switch off the oven from the main switch before attempting a bulb replacement. In difficult cases as this may be the case, a little application of ‘WD40’ directed at the thread part of the lense cover will help. Leave for an hour or two, then with a slighly dampened J Cloth give it a hearty twist (Anti-clockwise don’t forget) that should do the trick 😉
Replace with the correct ‘oven lamp’, clean away any WD40 and the jobs done :tup:
December 10, 2004 at 11:46 pm #121300clivejameson
…and while the lamp cover is off you can clean it by simmering in a pan of water with a little dishwasher detergent added…comes out like new!
When you put the cover back on just ‘nip’ it tight so you won’t have the problem again.
CliveDecember 16, 2004 at 7:05 pm #121301admin
KeymasterRe: creda oven
A late reply since I had to leave uk for a while.
Thank you very much Martin, and Clive.
Did it today (15-12-04) It was as you said, a bit of WD40, a wet cloth and it did the job. Thnx again guys.I looked for days to find an instruction manual for Hoover washing/machine, and couldnt find it, then I found your page. One of you stated that there are none. Lol.
Then I thought that you really know your onions. – so i posted my question.To conclude guys (I saw one guy ordering sumthing from you)_ if you have a light bulb for my Oven, pls send me one, since I wanna buy it from you. I need a contact number or an order form.
kind regards
Jack -
