Creda Oven
  • #15495
    Newburysteve
    Clutching at straws a bit here. The front glass fell out of my Creda Cordialle oven at the weekend and although I’ve traced the problem to the 2 small metal brkts at the bottom of the door working loose, as the glass fell out it snapped the right angled bacolite trim that runs along the base of the door and hides the brkts.
    As the oven is built in I’m unable to see the exact make and model numbers but it’s a brown cordialle, probably dated mid 90’s, single electric fan assisted oven with grill and it stands around 10 inches off the floor under a gas hob. The two controls for oven and grill are in the top left corner and there’s a dial clock with timing controls under it in the top right.
    A long shot I know but any hope of obtaining a new bacolite brkt/trim?
    #163799
    Re: Creda Oven
    It narrows down to about 10 differing variants the info you have given so far. But finding that all important model number (on the door frame or on the back) is vital 🙁
    #163800
    Re: Creda Oven
    It may even be on the edge of the trim surround at the bottom – you have to look up!
    Newburysteve
    Re: Creda Oven
    Thank’s for the clue. I’ve found a label under the front edge of the oven with the following info:
    Serial No: 988 C 012067
    Spec: 482060000LT
    Total load: 3KW
    (Had to read it with a mirror so I think that’s it).
    Does this help?
    #163802
    Dave_Conway
    Re: Creda Oven
    Part number 6225168 for the lower door trim at £10.20 ex VAT and carriage.
    An email to spares@ukwhitegoods.co.uk please if required 🙂
    #163803
    Newburysteve
    Re: Creda Oven
    Will order it now. Many thanks.
