Hi, Just changed main oven stat. the customer now says that the oven isn’t getting hot enough? the food is only partially cooked.
Also since changing the stat the rear left hob comes on with the front left hob and visa versa.
Anyone have a wiring diagram for this oven? I did make a note of all the wiring connections on the stat before i replaced it. Help!
many thanks.
Ashby
Re: Creda Oven Mod 48902. Spec 48902. Ser. 25100091
assuming you didnt touch any of the wires to the hob, there can be no connection. If you get the indicator discs on wrong, (some have a washer underneath to space them apart from the next one along,) turning one can also turn the next one along on by a kind of cog wheel action. Check also the indicator disc for the oven, they can come unglued and not indicate the correct temp.
