Re: Creda Oven not heating
don’t have any tech or info on this unit but
if you have blown a fuse and its controlled by a pcb then it is likely you have blown the tracks on the pcb
if it has blown it will be possible to repair the track by soldering wire across it after you have cleaned it. If the element is controlled by a relay on that board then you may also find the relay contacts are welded and you may also have to replace this
all this will test your soldering skills
