Creda Plan Europa Solar Plus oven
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Creda Plan Europa Solar Plus oven
  • #20000
    peter-h
    HI The main fan oven keeps tripping the house fuse box after it has been switched on for 2 or 3 min I understand that this is the element that is around the fan. I have removed the element and have put a resistance meter on it.
    If it is faulty what should the resistance be ?.
    or if it is ok what should the resistance be ?.
    The spec no is 48145000LB
    Help needed
    thanks Peter
    #185358
    Dave_Conway
    Re: Creda Plan Europa Solar Plus oven
    A resistance reading isn’t a good way of testing if it’s taking the house trip out, it needs to be tested for earth leakage with a meggar ideally 🙂
    It will almost certainly be the element though (model number required to identify the correct one).
    #185359
    P/no 6224745. An email to spares@ukwhitegoods.co.uk for prices and ordering.
    Dave_Conway
    Oops, sorry I missed the spec number 😳
    This is the one:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=338
    Merloni changed the part number for some reason 😕
    Dave 🙂
