hi
I have a creda reflections 48196 which is 4 years old ,today it tripped the rcd but when powered up the main oven will not heat up everything else works fine .Im presuming that the element has gone unless someone with technical knowledge can tell me otherwise.if this is the problem is it easy to access and do the repair.
any advice would be much appreciated 😀 😀
