Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › creda reflections model 48197
- This topic has 5 replies, 5 voices, and was last updated 18 years, 8 months ago by
susannora.
August 10, 2007 at 4:22 pm #29664
susannora
ParticipantHi, I have a creda reflection and the lighting behind the control knobs for temperature/on-off has gone out. Can anyone tell me how I can remove the panel to replace the bulb/strip light.
Thanks.August 11, 2007 at 12:35 am #224037aqualectric
ParticipantRe: creda reflections model 48197
The oven will need to be pulled out from the housing (6″ will do). Make sure it doesn’t tip up by supporting the underneath with a chair or ‘workmate’. There are 2 screws (1 either side) behind the fascia on the rim of the oven trim. Remove the knobs (apart from the knob closest to the middle – there is a reason for this) and then carefully pull out the clock buttons with the tips of your fingers.
Now undo the screws from the rear of the fascia. Holding the glass panel firmly, pull off the remaining knob and remove the panel from the oven. Doing it this way avoids the possibility of the glass panel being dropped as the fascia is unscrewed. 😉
Fitting the fluorescent tube is easy. Then refit as a reversal of removal: glass panel on, fit knob to hold it; fasten with screws and refit all buttons and knobs.
Source the fluorescent tube before you start the job – if you can’t get it, Dave can find it for you, just e’mail Shop@ with the model number.
Power off at the wall and the ‘fusebox’ before you start ANY work. Stay alive!!HTH,
Steve.
April 27, 2008 at 6:16 pm #224038snowy1998
Would it be similar take-apart for the 48196?
April 27, 2008 at 6:46 pm #224039iadom
ModeratorRe: creda reflections model 48197
48196 & 481297 look the same on the parts diagram.
April 27, 2008 at 8:52 pm #224040snowy1998
well i bit the bullet and had a go, its exactly as described!, all I need to do now is find a TL 8W/35 tube, dont seem to be many of that type listed, but i’ll have a butchers at the local sparky’s merchant 2mo’
thanks for all the helpApril 27, 2008 at 11:26 pm #224041Penguin45
Participant -
