Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Creda Reflections Oven Control Panel Lights Problem
- This topic has 7 replies, 3 voices, and was last updated 21 years, 8 months ago by
actonblue.
August 6, 2004 at 10:09 am #5978
actonblue
ParticipantI have a Creda Reflections Double Oven (Built in type) and the lights that illuminate the temperature selection for the grill and the ovens are not lighting up. The clock is working and so are the lights that indicate the oven has reached the selected temperature.
What I would like to know is:
How to access the lights?
What type of lights are they?
Is it easy to access them?
Is it a job for a DIYer?Thanks.
Colin
August 6, 2004 at 10:51 am #114909Dave_Conway
ParticipantRe: Creda Reflections Oven Control Panel Lights Problem
Colin, it will be a flourescent tube behind the glass control panel normally which involoves removing all the knobs etc and the glass panel, the tube should be behind there.
If you can post the model number I should be able to identify which tube you will need as Creda used a couple of different types.
Make sure it’s switched off and isolated from the main supply 1st before attempting any repairs !
Regards.
August 6, 2004 at 1:37 pm #114910actonblue
The Model Number is 48197.
How easy is it to remove the timer control buttons witout braking them.
Thanks.
Colin.
August 6, 2004 at 4:43 pm #114911Dave_Conway
Ah, it’s built in double oven then which may make things a little trickier.
The knobs just pull off as do the timer butttons, the glass should then be able to be removed by removing the outer glass trim, screws could be anywhere to be honest, if you’re unsure, I would get an engineer to do it for you.
The tube looks like a 13w mini fourescent as is the norm for these cookers.
August 6, 2004 at 6:24 pm #114912actonblue
ParticipantThere are a number of screws around the the control panel so I will see which release the panel
I am a bit concerned about the timer control buttons as they do not seem to come off easily and I do not want break them. Is there a knack to doing this.Where can I source the bulbs?
Thanks.
Colin.
August 6, 2004 at 8:35 pm #114913Dave_Conway
actonblue wrote:Is there a knack to doing this.
Yeah, pull ’em, they will come off. Grip the button with your forefinger and thumb then tug.
actonblue wrote:where can I source the bulbs?
There’s only one tube, I can get you one if required, let me know the wattage and length when you have got the panel off and drop me an email.
January 6, 2005 at 4:39 pm #114914admin
KeymasterRe: Creda S202PW SPIN DRYER
CAN SOME BODY PLEASE TELL ME THE WATTAGE OF THIS ITEM AS ITS TO BE USEDV FOR A CANAL BOAT
January 6, 2005 at 5:07 pm #114915Dave_Conway
If it’s a 48197 as above, follow this link for the user manual, it will have the spec in there for you:
https://www.theservicecentre.co.uk/macr … odel=48197
